2003 Hyundai Tiburon cv joint?
89,000 MILES • 6 CYL • FWD • AUTOMATIC
JERSEYCARP
I have a ticking noise from the front drivers side. i can feel it under my left foot while driving. The noise gets faster as i accelorate and sometimes i can hear a grinding noise. it sometimes goes away but not for long. I can move the tire up and down and it feels only a little loose, side to side is tight
May 8, 2008 at 2:40 AM
SERVICE WRITER
  • 9,123 POSTS
There should be no play...at all.
IF it seems like a roar or a hum and may change when very one way or the other, it is most likley a wheel bearing. Typically you would also have up and down play if you push pull at the 6 and 12 positions or the 3 and 9 positions with your hands. May also have a ball joint problem present in the event the axle is bad as there would be no play when an axle goes bad.
May 8, 2008 at 6:09 AM
