2003 Hyundai Tiburon Air Conditioning Problem
98,000 MILES • 4 CYL • 2WD • AUTOMATIC
CDILWORTH
The air conditioning will only work when the dashboard knob is on full blast (there are 4 settings and only 4 will work). Also, if the air conditiong is on, the car will squeel for a while when the car is first turned on and wont stop until it is driven for a minute or so. What could be the problem? The serpentine belt, or more?
Sep 25, 2010 at 1:22 AM
KHLOW2008
  • 41,812 POSTS
Hi cdilworth, Thank you for the donation. The squealing noise should be from the drivebelts. Check the drive belts conditions and tension and adjust/replace as necessary. The blower motor working only in highest speed mode indicates the power transistor is bad. The power transistor is located at the blower motor housing.
https://images.2carpros.com/forum/automotive_pictures/192750_PowerTransistor03TiburonFig87_1.jpg
Sep 25, 2010 at 3:56 AM
