2002 Hyundai Tiburon Cat cenverter
2002 HYUNDAI TIBURON
70,000 MILES • 6 CYL • 2WD • MANUAL
ASKINNER
I have a 6 year old Hyundai coupe. It is the 2 litre 16v 136 hp. Engine code G4GC. It is spanish and left hand drive. The exhaust manifold has a crack in it so need to by a new one. Unfortunately it is joined with the cat converter so the whole thing will cost about 1000 usd (1200 euros). Does anyone know if one would fit from the same car, same year but engine code G4GF and it is english right hand drive. Not sure if the manifold and cat were changed from one engine to the next. If it is the same then I can get one for 300 usd.
Thanks
Adam
May 28, 2009 at 10:56 PM
  • 110,240 POSTS
I don't have the cross reference you need. I would think a salvage yard will have it. Also, if you call the parts store with the new one, they should be able to tell you if the part number is the same for both.
Sorry I couldn't be of more help. We always try to direct people to use direct replacement parts. Regardless, this may be a direct replacement.
Jun 2, 2009 at 6:10 AM
