2001 Hyundai Tiburon wont start
114,000 MILES • 4 CYL • FWD • AUTOMATIC
RSTLNE
My car has been sitting for a few weeks, and it started a couple of times during those weeks. It just started a few days ago, but when I tried to start it, it sounds like it's going to start but won't. AAA came to try to jump start it but it won't start. Battery seems ok lights & radio still work....
Nov 16, 2009 at 8:26 AM
  • 75,988 POSTS
Let do below for a start to determine if its fuel or spark related issue and get back asap.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Nov 16, 2009 at 8:50 AM
ERICJENTCAR
wont start turns over but no spark , i looked at timing belt all belts, sencors cam and crank and the ignition coil is good please help email me at jentek_owner@yahoo.com
May 8, 2010 at 5:00 AM
  • 75,988 POSTS
If it doesn't apply disregard it-Check and test the distributor pick-up coil and ignition control module
May 8, 2010 at 11:06 AM
