2000 Hyundai Tiburon Starter
SDCORN1684
Engine Mechanical problem
2000 Hyundai Tiburon 4 cyl Front Wheel Drive Manual
How would you go about taking the starter out? Is one of the bolts on the Transmission?
Mar 11, 2009 at 1:49 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Remove or disconnect the following: Negative battery cable Speedometer and shift control cables Starter electrical connectors Starter motor
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_320.jpg
Install or connect the following: Starter motor and torque the bolts to 25 ft. lbs. (34 Nm) Starter electrical connectors Speedometer and shift control cables Negative battery cable Thanks for using 2CarPros.com!
Mar 11, 2009 at 4:27 PM
