2000 Hyundai Tiburon Gas Tank
14,800 MILES • 4 CYL • 2WD • AUTOMATIC
RMYERS928
My engine light is on....
My gas tank will not accept gasoline from the gas station's pump very easily, recently....It "clicks" off every 10-20 cents and it takes about half an hour to fill the tank...I have tried 5 gas stations with the same result...
What is the cause and...
Are these issues related?,
Thank You
May 16, 2009 at 12:39 PM
  • 110,248 POSTS
The problem is either a check ball where the filler goes into the tank is stuck or sticking (designed to not allow fuel to escape the fuel tank in the event of a roll over), or if you notice, running along side of the large filler tube is a smaller breather type pipe that could be plugged not allowing air to exit the tank while filling.
Jun 2, 2009 at 6:25 AM
