2000 Hyundai Tiburon fuse
2000 HYUNDAI TIBURON
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
TSTERLING80
i changed the fuse to my taillight and realized there is nothing to grab the fuse (the metel prong is missing) therfore the fuse will not work when its in what should i do?
Mar 8, 2010 at 9:42 AM
  • 110,244 POSTS
First, disconnect the battery. Next, remove the fuse panel so you can access it from the rear. After you can inspect it, check to see what has allowed the prong to push through.
May 24, 2010 at 5:54 AM
