2000 Hyundai Tiburon flooding
135,000 MILES • 4 CYL • 2WD • AUTOMATIC
MRNCE
I have been having an increasing problem with my car being difficult to start. It cranks and cranks, but will not engage. When it finally does, there is a puff of smoke that is emitted from the exhaust. It smells of gasoline as if it is flooding.
Jul 22, 2009 at 1:09 AM
  • 110,248 POSTS
Is the smoke black, blue, or white in color?
Aug 5, 2009 at 4:10 PM
MRNCE
White. It is not all of the time. I had the fuel pump replaced still starting hard. Starts right up with starting fluid. Occassionally popping a code that the Idle control is bad, but again not all the time. I just don't want to keep guessing.
Aug 6, 2009 at 4:35 AM
  • 110,248 POSTS
Have you ever checked to make sure the head gasket isn't leaking? WHite smoke usually indicates coolant getting into the combustion chamber. You could test compression. Also, an idle air control valve could cause a hard start.
Aug 6, 2009 at 9:08 AM
MRNCE
Thankyou and I will check pressure. My mechanic did not think it was head gasket mainly because of the smell of raw gas.
Aug 7, 2009 at 12:19 AM
