2000 Hyundai Tiburon down shifts
IRONMIKE
Transmission problem
2000 Hyundai Tiburon 4 cyl Front Wheel Drive Automatic
my car will down shift for no reason while going the same speed , and then it wont shift back to the next gear i have to turn the car off and then the car will reset it self what do you thank that could be that is makeing that happen
Dec 6, 2008 at 5:49 AM
IMPALASS
  • 3,112 POSTS
Hello –
Well, what I need you to do is please go to Auto Zone (AZ) or O’Reilly’s (OR) and for FREE they can pull the codes to the car. Most important: Once they check your codes, if they find something and you don’t get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. While there for FREE also they can bring their tester out and check your battery, alternator and starter.
Get back with me once you have pulled the codes so we can take it from there. Also, I just want to make sure you have checked the fluid level and it is sitting correct?
Dec 6, 2008 at 4:17 PM
