2000 Hyundai Tiburon all kinds of problems
SCRAPMETAL
2000 Hyundai Tiburon 4 cyl Front Wheel Drive Automatic
My car has been acting funny when i sit in drive at a red light or something it feels like it wants to stall. My check engine light is on so I took it to Autozone and they ran the diagnostics test. The test came back with these results:
P0441evaporative emission control system
p0743 torque converter clutch circuit electrical
p0760 shift solenoid C malfunction
p0755 shift solenoid B malfunction
p0750 shift solenoid A malfunction
p0765 shift solenoid D malfunction
p0745 Pressure control solenoid malfunction
now i have a couple of questions 1: Do you think this is something that would require a new transmission?
2: if i decide to repair this myself is this stuff located in the transmission?
3: Do you think it might be an electrical thing (ground wire or faulty corroded wire)?
4: how easy would this be to fix? And how would i go about doing it?
It seems that they only made one hyundai tiburon because you can never find any information on it. No manuals or nothing. Thanks in advance for the help.
Feb 23, 2010 at 12:33 PM
  • 31,937 POSTS
Hi there,
I would be thinking that it will be electrical as i can't see all those faults happening at the same time, i would first contact a transmission specialist and get their advice as they may have come across this problem before, myself..i have not seen this before. There may be a communication fault with the Transmission control unit check that all the plugs and looms for the transmission are not damaged in any way, start here.
mark (mhpautos)
Feb 23, 2010 at 3:15 PM
SCRAPMETAL
thank you for yor reply. I will call around today.
Feb 24, 2010 at 12:21 AM
SCRAPMETAL
when i called the transmission place the guy told me that the sputtering is the purge valve and i need to have it replaced and hes crazy if he thinks im gonna pay him 400 dollars to do it. Ive read that it takes about 20 minutes to do. I guess being a woman he thinks i cant do my own car repairs (i need to know what im doing but i can do it) ive done all types of repairs. I know what the purge valve looks like but i have no idea where it is located in my tiburon. is there any way anyone has any idea?
Feb 24, 2010 at 12:10 PM
