1998 Hyundai Tiburon Oxygen sensor
1998 HYUNDAI TIBURON
98,000 MILES • 4 CYL • 2WD • AUTOMATIC
WHIZKID
I need to replace oxygen sensor for my tiburon fx 1998, any diagrams and explanation to do it myself would help a lot.
Jun 17, 2008 at 4:29 AM
BLACKOP555
  • 10,386 POSTS
bascially unhook the o2 wiring harness and run the engine till its warm, be careful not to burn yourself.
with engine warm teh threads will be expanded and the sensor easier to remove.
you will need a special socket to remove it as the wires will hit the top of a normal socket and damage the sensor or wiring if you can maange to get the socket on it. dont use a wrench or you will probably round it off unless you have a large 6 point.
Jun 17, 2008 at 6:12 AM
WHIZKID
[quote:a82bc88b92="blackop555"]bascially unhook the o2 wiring harness and run the engine till its warm, be careful not to burn yourself.
you will need a special socket to remove it as the wires will hit the top of a normal socket and damage the sensor or wiring if you can maange to get the socket on it. dont use a wrench or you will probably round it off unless you have a large 6 point.[/quote:a82bc88b92]
is there any diagram for this as I am newbie and dont know where the o2 harness or sockets are..sorryyy..
Jun 17, 2008 at 8:53 AM
BLACKOP555
  • 10,386 POSTS
are you positive you want to do this?
cant say ive ever heard of a diagram for this.
the o2 sensors are located on the exhaust piping, and the harness is what attaches to them.
Jun 17, 2008 at 1:06 PM
