[quote:a82bc88b92="blackop555"]bascially unhook the o2 wiring harness and run the engine till its warm, be careful not to burn yourself.
with engine warm teh threads will be expanded and the sensor easier to remove.
you will need a special socket to remove it as the wires will hit the top of a normal socket and damage the sensor or wiring if you can maange to get the socket on it. dont use a wrench or you will probably round it off unless you have a large 6 point.[/quote:a82bc88b92]
is there any diagram for this as I am newbie and dont know where the o2 harness or sockets are..sorryyy..
Jun 17, 2008 at 8:53 AM
