Engine Mechanical problem
1998 Hyundai Tiburon Two Wheel Drive Automatic
Found this car on craigslist i like it however i am not sure if it is actually worth it. so below is a copy and paste of what they posted. I am not sure the cost or the time and energy that i will need to put in it so if you could just give me so enlightenment on this it would mean alot. (The car will not run at the time has broke cam shaft. I have done all the work to this car and now tired of putting money in it A lot of work has been done to this car new plugs, ,wires, radiator, water pump, the hole head gasket set, timing belt , brakes, tires are not that old starter was just rebuilt could be nice car the ac works)
May 9, 2010 at 4:06 PM
