1997 Hyundai Tiburon rough idling
16,500 MILES • 4 CYL • FWD • AUTOMATIC
GSTOESSEL
I am driving my son's 1997 Hyundai Tiburon. When I first start it up in the morning it runs very rough. If I turn on the air conditioning it runs even rougher. I try to drive down the street and it runs horribly and just lopes along. Once it has warmed up a bit it runs fantasiclly.
Aug 21, 2008 at 11:24 AM
2CARPRO JACK
  • 11,533 POSTS
Any check engine light? does it overheat? use coolant? If th eengien light is or has come on,. have it scanned for codes, it will probably have a misfire code that will point to which cylinder to start with. Could be an injector bleeding down overnight, or spark issue or a very slight head gasket leak that is wetting the plug with coolant
Aug 22, 2008 at 5:21 AM
