1997 Hyundai Tiburon ignition or starter?
128,000 MILES • 4 CYL • FWD • MANUAL
SHIVA769
I can't figure out what's going on with my car. There's plenty of power but it won't turn over. The fuse box clicks when I turn the key but there's nothing from the starter area. Could this be an ignition coil problem? Or is my starter just out?[img:5fccd76722]http://www.2carpros.com/forum/automotive_pictures/257065_10511036255001030_1.jpg[/img:5fccd76722]
Oct 16, 2008 at 8:31 AM
  • 75,988 POSTS
Do a battery capacity test-if it passes make sure the its clean and tightened properly. Below is your starter control circuit-if you wish to start-find the clutch switch at the pedal support bracket disconnect it and jumper it and see what happens if it continues track it by using the diagram below
https://images.2carpros.com/forum/automotive_pictures/12900_st1_22.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_st2_20.jpg
Oct 16, 2008 at 8:43 AM
