Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Hyundai
Sonata
Brakes
Rotor
Replace/Remove
2007 Hyundai Sonata rotor replacement
2007 HYUNDAI SONATA
49,684 MILES • 4 CYL • FWD • AUTOMATIC
EKLAZZ
MEMBER
1 POST
How do I replace the rear rotors
Aug 24, 2010 at 4:49 AM
BLUELIGHTNIN6
Experienced Mechanic
remove wheel, remove guide rod bolt from caliper. raise caliper assembly out of way. remove brake pad shim, retainer and assembly in the caliper bracket. now that caliper and pads are off the rotor will come off.
Mar 15, 2021 at 10:53 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
