HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Hyundai
Sonata
Electrical
Battery
2005 Hyundai Sonata wrong size battery
CSEWELL82
MEMBER
2005 HYUNDAI SONATA
Electrical problem
2005 Hyundai Sonata 4 cyl Front Wheel Drive 124000 miles
can the wrong size battery cause my headlights to blow out over and over again?
Thursday, March 11th, 2010 AT 3:26 PM
MECHANIC
If it is a 12 volt battery, no. If this is happening, have the alternator output checked. The voltage regulator may be bad and causing the problem.
Let me know what you find.
Monday, May 24th, 2010 AT 10:44 AM
Please
login
or
register
to post a reply.
Related Battery Content
2006 Hyundai Sonata
Electrical Problem 2006 Hyundai Sonata Two Wheel Drive Automatic I Just This Car 2 Weeks Ago, I Found Ants In My Fuse Box Now My Car...
Asked by
evasquez87
1 ANSWER
2006
HYUNDAI SONATA
VIDEO
How to Charge an Automotive Battery
Instructional repair video
GUIDE
Battery Connected Backwards
It is easy to connect a battery backwards and it happens more than you think, so don't feel bad if you are here for that reason. Your car has safeguards built in to help...
1997 Hyundai Sonata Voltage
Im Having Trouble That Seems Like My Alternator But That Checks Out Ok, I See On This Forum, The Amps Can Be Ok But If The Voltage Is Low...
Asked by
elln50
1997
HYUNDAI SONATA
How to Replace the Battery in a Modern Car
Battery Replacement
