2005 Hyundai Sonata hard starting
122,567 MILES • 4 CYL • FWD • AUTOMATIC
CHACHAGIRL0
wont start after filling the tank
Mar 25, 2009 at 6:40 PM
  • 75,988 POSTS
Let do below for a start to determine if its fuel or spark related issue and get back asap.
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Mar 25, 2009 at 9:31 PM
