Finding tune up info is tough, and finding any good info on hyundais can be difficult.
If I remember right the plug replacement calls for about two and a half hours, which is way off the mark. It is much less to do. The front three are pretty easy. Just pull off the engine cover and they are right there. the back three, you need to pull off the coil pack assys. they are all attached to a bracket and the bracket just gets unbolted and then you have access. The take platimum plugs, I would us ngk brand on this one. Be very careful gapping these. The platimun can scratch off. Hopefully they are gapped right out of the box.
Fuel filter is in the tank if I remember right...I wouldn't touch it if it is.
Timing belt should be done at 60,000 on this one if it were mine.
Feel free to ask away.
Mar 22, 2008 at 5:20 AM
