2004 Hyundai Sonata removing rear rotor
70,000 MILES • 4 CYL • 2WD • AUTOMATIC
PAPAWAYNE
I was removing the rear rotor, with brute force, and the 2 springs inside the emergency brake, came out and it's impossible to put them back. Help!!!!!!!!!!!!
Jun 17, 2010 at 9:25 AM
DOCFIXIT
  • 18,828 POSTS
Did you remove the two set screws in rotor face to flange? when you removed parking brake cable are thoews the springs? if yes see diagram they are easily refitted
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_490.jpg
Mar 15, 2021 at 11:10 AM
