2004 Hyundai Sonata PO130 Code
91,000 MILES • 6 CYL • FWD • AUTOMATIC
WILL202XGI
After replacing all 4 O2 sensors I'm still getting a PO130 code. Could any other component cause a PO130 code?
Jun 6, 2008 at 11:27 PM
  • 75,988 POSTS
The O2 sensors are they OEM parts?
A code P0130 may mean that one or more of the following has happened:
The oxygen sensor is faulty
The wiring to the sensor is broken / frayed
There is an exhaust leak
Possible Solutions: The simplest thing to do is to reset the code and see if it comes back.
If the code comes back, the problem is more than likely the front Bank 1 oxygen sensor. You will likely wind up replacing it but you should also consider these possible solutions:
Check and fix any exhaust leaks
Check for wiring problems (shorted, frayed wires)
Check the frequency and amplitude of the oxygen sensor (advanced)
Check for a deteriorating / contaminated oxygen sensor, replace if necessary
Check for inlet air leaks
Check the MAF sensor for proper operation
Jun 6, 2008 at 11:33 PM
DOCHAGERTY
  • 9,606 POSTS
Hyundai uses similar electronics to BMW and this issue can be due to software. A possible reflash could be the solution.
Jun 7, 2008 at 3:25 AM
