Where is the fuse for the fuel door
2004 HYUNDAI SONATA
65,000 MILES • 6 CYL • 2WD • AUTOMATIC
TGAR847
It quit opening and the manual was not helpful. The wife has to open the trunk when she gets fuel.
Jul 1, 2010 at 8:28 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Check fuse # 8 (15 amp) in the passenger compartment junction block. This fuse protects the fuel filler door and the trunk lid switch circuits.
If the fuse is okay check for power through the switch. Here is a guide and the fuel door wiring diagram to show you how.
Check out the diagrams (below).
Cheers
Jul 1, 2010 at 11:34 AM
ENESHAD
I had this problem with my car. It was the switch that was bad.
May 2, 2018 at 5:01 AM
ADALLEN52
  • 5 POSTS
how do i replace the fuel filler door?
Jul 14, 2020 at 3:56 AM (Merged)
I attached the process on how to replace the actual door. You actually remove the insert and the door and hinge comes with it.
Let us know if you have more questions. Thanks
ADALLEN52
  • 5 POSTS
I am talking about the door you open to get to the fuel cap?
ADALLEN52
  • 5 POSTS
thank you.
You are welcome. Please come back to 2CarPros next time. Thanks
