2004 Hyundai Sonata blower
2004 HYUNDAI SONATA
91,000 MILES • 6 CYL • FWD • AUTOMATIC
TSSRWM
The blower is not working on my AC. I can tell the compressor is working because I can feel cold air seeping through the vents, but the blower doesn't work. When I first noticed it, the blower did not work at all. About an hour later, I tried it again and the blower worked but only on level 2, not 1, 3 or 4.
The blower will not work even with the AC turned off.
Is it the blower motor?
Jul 7, 2008 at 9:28 AM
KHLOW2008
  • 41,814 POSTS
Hi tssrwm,
If it does not work in other speeds, not likely to be the blower motor. Give the motor some knocks and see if it works in all modes.
I suspect it is the resistor.
Jul 9, 2008 at 4:41 AM
