2004 Hyundai Sonata battery problems
2004 HYUNDAI SONATA
62,000 MILES • 6 CYL • FWD • AUTOMATIC
SOOKSG
Hi there,
I have a battery problem with my Huyndai Sonata 2004. I bought this new car on Dec 04. Here are the problems I had with my battery.
1. On Dec 05, the car battery was changed.
2. On Nov 06, the battery terminals were cleaned up as there were corrison on them.
3. On Apr 08, alternator was replaced.
4. Sep. 2, 08, the battery terminal was cleaned up again as there were corrison on them again.
5. Nov. 21, 08, the car wouldn't start again. we dont know what is the problem.
It doesn't look like starter is a problem as the car starts when we jupmed it with another battery.
what should I check at this point?
A test result that is done by a service man today said ok. but I am not sure whether it is a battery problem. Should I change a battery?
I am wondering whether I need to ask a service center to find out whether something in my car is discharging the battery.
I am also wondering whether the alternator which was replaced could be a problem.
Thanks for your help.
Sue
Nov 22, 2008 at 5:18 PM
  • 31,937 POSTS
Hi there,
Get the battery load tested as This is the only true way to test a battery for condition, have the alternator charge rate checked, check all terminals & earth points are clean & tight, and get a current draw test done on the electrical system. this is an easy test to do, if the mechanic is not sure about this, re post and i will detail the procedure.
Mark (mhpautos)
Nov 22, 2008 at 5:25 PM
