2004 Hyundai Sonata
70,000 MILES • 4 CYL • FWD • AUTOMATIC
MJOHNSTONBOYCE
If the car had a coolant leak and a waterpump leak would it leak out on the ground or would I see some type of evidence that the car is leaking from some where?
Jun 9, 2008 at 12:07 PM
KHLOW2008
  • 41,812 POSTS
Hi mjohnstonboyce,
If you had coolant in the system, any leakage would stain the floor. If the leakage is very minimal, you might not notice the stains as it might just look like ordinary AC water.
If the leakage is from joints, you would see staning around them, in such case the leakage might not get to the floor as the heat would dry them up.
Jun 11, 2008 at 1:31 AM
