2003 Hyundai Sonata PO401 check engine code
2003 HYUNDAI SONATA
101,000 MILES • 4 CYL • 2WD • AUTOMATIC
TOODOG733
After researching many articals on this trouble code (PO401) EGR insuffient flow I was first lead to believe a bad EGR valve or actuator solenoid was at fault. Then I came accross some information on the differential pressure sensor EGR (DPFE) a thought it may be to blame. All the articals I could find were on Fords and I have a Hyundai. My question is, do all cars use a DPFE sensor, specificly does my 03 Hyundai Sonata have on and where is it located, and what do you think I should do first.
Sep 15, 2008 at 7:41 AM
Clean out the EGR valve/passages and make sure its getting vacuum thru the vacuum solenoid
Sep 15, 2008 at 7:51 AM
