2003 Hyundai Sonata Hesitating
CRYSTAL_DUNN
Engine Performance problem
2003 Hyundai Sonata 4 cyl Two Wheel Drive Automatic
My Sonata has started hesitating and I was just wondering what could be causing this and what do I need to do to get it to quit. I am a single mom on a budget, so the cheaper the cost of repair the better. Thank you.
Jul 8, 2010 at 7:02 AM
  • 75,988 POSTS
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jul 8, 2010 at 7:53 AM
