2003 Hyundai Sonata blowerfan resistor
PAINTERMAN 84
Heater problem
2003 Hyundai Sonata 4 cyl Front Wheel Drive Automatic
where is the blowerfan resistor located on my 2003 Hyundia Sonata
Nov 12, 2008 at 11:13 AM
  • 75,988 POSTS
Its behind right side of dash on HVAC housing
Nov 12, 2008 at 1:23 PM
B SEA
[quote:1bd28ec22b="painterman 84"]Heater problem
where is the blowerfan resistor located on my 2003 Hyundia Sonata[/quote:1bd28ec22b]
On my XG which is similar, I had to remove the glove box to get at the unit. If the heater control is digital, you may not have resistors but rather a pulsed circuit thru power transistors. On mine I replaced that hi-tech expensive unit with 2 ceramic ballast resistors to give me an old fashioned 3 speed blower on a toggle switch. It's worked fine for 3 uears now.
B.Sea
Nov 15, 2008 at 2:03 PM
