2003 Hyundai Sonata Battery
73,000 MILES • 4 CYL • 2WD • AUTOMATIC
SAWYERTOM
the battery light came on in my car during the day. later that night the entire car lost power. I had the battery charged and then had a tester put on the alternator and it said the alternator was giving out power. But now the battery light is back on and car is loosing power again. what could be the problem if it is not the alternator
Jul 6, 2008 at 12:26 AM
FORD136
Check the resistance in the pos. battery cable. This is a common problem with hyundai's. I have replaced many of these.
Jul 6, 2008 at 1:12 AM
KHLOW2008
  • 41,812 POSTS
Hi sawyertom,
When the charge light comes on, check the alternator charging again at alternator main post and battery.
It could be worn carbon brushes which is causing the intermittent charging and not charging.
Jul 6, 2008 at 3:40 AM
DMCOKE
This is funny...I have a 2003 Hyundai Sonata 4 cyl Two Wheel Drive Automatic with 85,000 miles. My light came on (July 10) and I went and had the charging system tested because my battery was only two years old. The "boys" told me my alternator was fine and it was my battery it could not be charged up all the way. I took it back to the store I purchased the battery from and they tested the battery and it showed "good". Rather than argue with me, they changed out my battery since it was still under the "free replacement" warranty. I am thinking...kewl I am good to go! NOT! Driving down the road three days later and everything starts shutting down; I make it within ONE block of the shop and it dies. I have it towed and $600 later it WAS the alternator! The $600 includes replacing the two belts, since they will have it torn apart anyway! Good luck!
Jul 15, 2008 at 5:51 AM
