2002 Hyundai Sonata Too much pressure inside radiator, tubi
2002 HYUNDAI SONATA
95,000 MILES • 6 CYL • 2WD • AUTOMATIC
KAYTWOHG
cracked radiator while driving, noticed by temp gauge going into red. The craked plastic top replaced with metal. The problem is that its builts high pressure keep on bursting tubing(horsepipe). take-off power is lost since this problem. What could be the cause?
Nov 2, 2009 at 7:47 PM
SERVICE WRITER
  • 9,123 POSTS
Bad head gasket, or head will cause an over pressuring of the cooling system. There is a chemical test that can be done to find exhaust gases in the cooling system.
Nov 2, 2009 at 10:36 PM
