2002 Hyundai Sonata timing belts
SHYGIRL2148
  • 2002 HYUNDAI SONATA
  • 4 CYL
  • FWD
  • 102,000 MILES
2002 hyundai sonata with 102000 miles 2.4 automatic, recently my car died going down the road, and wouldn't start back, I had it towed home and found out the timing belt had broke, it has been replaced now, but car still won't start. Timing has been checked and checked again, looks as tho it is timed correctly but still nothing. Already checked to make sure battery wasn't low. Anyone have any suggestions what else could be.
Sunday, July 25th, 2010 AT 9:33 AM
MERLIN2021
  • 17,250 POSTS
Were the valves checked for damage? Valves can get bent if the belt breaks while driving. Does the engine crank but not start? Or no crank?
Sunday, July 25th, 2010 AT 9:45 AM
EDWARD.S
  • 166 POSTS
Hi, When The timing belt broke, Did You Crank It Several times? If So It May have bent valves, Do a compression test Of all Cylinders First. This May be A interference Engine, Which Means That If you Crank It With The belt off, The valves Will Touch the pistons And bent.
Hope This Helps You,
Good Luck
Edward S.
Sunday, July 25th, 2010 AT 9:52 AM
SHYGIRL2148
Yeah it does crank, just won't start. Will have the valves checked, thank you both
Sunday, July 25th, 2010 AT 10:12 AM
MERLIN2021
  • 17,250 POSTS
Your welcome. If the engine cranks faster than it used to, it is probably bent valve(s).
Sunday, July 25th, 2010 AT 10:51 AM
