2002 Hyundai Sonata Power door locks not working
139,400 MILES • 4 CYL • FWD • AUTOMATIC
CODEXKEY
Just purchased the car used. The power door lock button (located on the driver's-door console) only unlocks the doors. It does not lock them. While driving, the power lock will spontaneously engage and unlock all the doors. Also, on the same console, the power window switch that controls the passenger-side window does not work (though the other three switches on the driver's-side door console work fine). Do I need to replace the entire console or is there something wrong with a fuse or something like that?
Aug 20, 2009 at 6:36 AM
PANADOL
  • 16 POSTS
[quote:eade75d452="codexkey"]Interior problem
2002 Hyundai Sonata 4 cyl Front Wheel Drive Automatic 139400 miles
Just purchased the car used. The power door lock button (located on the driver's-door console) only unlocks the doors. It does not lock them. While driving, the power lock will spontaneously engage and unlock all the doors. Also, on the same console, the power window switch that controls the passenger-side window does not work (though the other three switches on the driver's-side door console work fine). Do I need to replace the entire console or is there something wrong with a fuse or something like that?[/quote:eade75d452]
Normally when u driving the power lock will auto lock itself.maybe is your central lock control module faulty...Then i think u have 2 chk the p/window switch and wire harness loose on d passenger side..b4 u replace main switch on driver side....
Aug 26, 2009 at 2:54 AM
