2002 Hyundai Sonata Main Fuse location. No electrical, a/c,
2002 HYUNDAI SONATA
122,000 MILES • 6 CYL • 2WD • AUTOMATIC
DPOLLA8
We checked the fuse box under the hood and inside under the steering wheel and changed all the blown fuses.
Story: My husband took a new battery out from another car to replace the old one, but it was not the right one. So it messed up the car. At first we could still drive it when we put the old one back in, and so we changed out all the blown fuses. But the radio, a/c and a few other electrical things still did not work. Then in the morning we started it again, but decided not to drive it. Next thing you know it won't even turn over! We are wondering is there a main fuse somewhere, not with the fuse box under the steering wheel inside or with the fuse box under the hood, but a seperate one somewhere? We changed the one by the battery going to the alternator. Or does someone know what we need to do to fix this? Thanks!
Aug 4, 2009 at 4:03 PM
Try the fusible link between the battery positive post and alternator
Aug 4, 2009 at 5:55 PM
DPOLLA8
Thank you. We did try it, but still to no avail.
Aug 5, 2009 at 6:57 AM
Next thing you know it won't even turn over! Is it cranking over and refuses to start if so check for spark and fuel pressure
Aug 5, 2009 at 7:01 AM
