2002 Hyundai Sonata Loses power/altenator ok, battery repla
DOLLYLAMA29
  • 2002 HYUNDAI SONATA
  • 4 CYL
  • FWD
  • 124,000 MILES
While driving my Hyundai on the freeway, I started losing power, my radio shut off, spedometer wouldn't move and my battery light and other dashboard lights flashed on. I pulled into a gas station, turned off the car and it would not start up again. I have AAA, it was towed to a mechanic who ran diagnostics, said we only needed a new battery. They said the altenator was good. Got the new battery and when I picked up my car, went through a drive through and as I left I noticed I was losing power again. Took it to another mechanic, they checked the altenator, said it was good and not sure why I'm losing power, they charged my battery and I left. While Driving home I noticed my car surging and then I lost power again, I live in a remote location where it's a 75 mile drive to the mechanic. My cruise control is also not working, it will turn on and then it quickly turns off on its own.
Any ideas why this is happening? The mechanics at both locations said they do not know why I am losing power.
Both mechanics said that I will probably need to go to a dealership, however the closest dealer is a 3 hour drive. I am also worried that they will try to take advantage, I'd like to be prepared with as much info as possible so I don't get scammed by the dealership.
Monday, June 14th, 2010 AT 1:21 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Alt may work when tested but maynot be charging batt. Coming off POS battery term there is a 120amp fusiable link check to see if voltage is present before and after link. Also place volt meter across batt terms voltage at 1500rpm 14.5 to 15.5
Let me know
Thaks for donate
Monday, June 14th, 2010 AT 11:41 AM
DOLLYLAMA29
Checked link and voltage present before and after.
We have a volt meter - was at 12.26 before starting car and at 14.7 after starting car.
Borrowed a battery charger, the batterfy fully charged and volt meter reads 16. But same happened previously and then our battery drained down once AC, radio & lights were turned on.
Car has also been surging when driving.
Tuesday, June 15th, 2010 AT 1:36 PM
DOCFIXIT
  • 18,828 POSTS
Put volt meter across batt terms as before run engine at 1500rpms turn on A/C, lights, every thing at steady 1500 what happens to battery voltage?
Tuesday, June 15th, 2010 AT 1:43 PM
