2002 Hyundai Sonata cleaning fuel injectors
2002 HYUNDAI SONATA
100,060 MILES • 4 CYL • FWD • AUTOMATIC
02SONATA
hi
is it recommended to clean fuel injectors? is there anything that i should notice to initiate the cleaning or should it be done by default? it recently crossed 100k mile mark. never cleaned fuel injectors before.
Jul 13, 2010 at 1:59 PM
BLUELIGHTNIN6
  • 16,542 POSTS
you can keep injectors clean by running a bottle of fuel injector cleaner/fuel treatment in with your fuel fill ups.
Jul 13, 2010 at 6:23 PM
02SONATA
[quote:bc04b5f87f="bluelightnin6"]you can keep injectors clean by running a bottle of fuel injector cleaner/fuel treatment in with your fuel fill ups.[/quote:bc04b5f87f]
thanks for the response! i've used stp fuel injector cleaner bottle 2 times. should i be using it during every fuel refill? or is there any frequency of use? is stp brand good? i read in some of the fourms that it damages nylon in the fuel tank filter. can you please suggest good brands, that are safe to the car?
Jul 14, 2010 at 3:49 PM
BLUELIGHTNIN6
  • 16,542 POSTS
i prefer Techron myself, but Redline Fuel Cleaner is also good stuff to use. Just read the bottle's directions, some may say every other fill up while other's say every fill up.
Jul 14, 2010 at 4:00 PM
