2002 Hyundai Sonata Acceleration problems
98,000 MILES • 4 CYL • FWD • AUTOMATIC
BIGT69694321
About a month ago my car was shaking and there was barely any acceleration when i would hit the gas until i started going then it was fine but it was still shaking. My mechanic said it was the Engine coils, So i got both changed. Now the engine light is back on and once again barely any acceleration but this time its not shaking. It seems to start ok, and again once i get to a certain speed its fine until i stop. Please help Ive spent enough money on this problem to have it happen again. Thanks you very much.
Mar 7, 2008 at 11:18 AM
BMRFIXIT
  • 19,053 POSTS
Check engine will come on every time computer detect a problem and will set a code
indicating troubled area
as a 1st step you need to have the system scanned for code s
you can try local part store or shop for help with reading and getting the codes
you may post them here for more help
good luck
Mar 7, 2008 at 11:27 AM
