2001 Hyundai Sonata washer fluid does not spray out
115,933 MILES • 6 CYL • FWD • AUTOMATIC
LAMAR EARLEY
washer fluid comes out very little most of it goes on hood. what do i need to look at. if it is the filter wher is it located
Jun 14, 2008 at 6:17 AM
KHLOW2008
  • 41,812 POSTS
Hi lamar earley,
Check if any of the nozzle hose is disconnected under the bonnet.
Check if hose is clamped by bonnet when closing it.
Check if nozzle is clogged. Use fine wire to poke the outlet, take care not to use too much force or allow the wire to break inside the nozzle.
Jun 14, 2008 at 6:40 AM
