2001 Hyundai Sonata vibrating
230,000 MILES • 6 CYL • FWD • AUTOMATIC
ALEX TUAZON
hi i have 2001 sonata v6, i tune up my car, change the spark plugs n wires, then when i start the engine, the check engine sensor/light came out, and there is a vibration to the engine n its not running smoothly, how can i fix this
Apr 24, 2008 at 4:34 PM
  • 31,937 POSTS
Hi there, check the fault code reading first, you may have a faulty plug or lead, did you check the plug gaps first, one may be cloyed up. have a look at the code set first.
mark (mhpautos)
Apr 24, 2008 at 6:55 PM
