2001 Hyundai Sonata spindle replacement?
68,000 MILES • 6 CYL • FWD • AUTOMATIC
TREVOR1963
The vehicle was broadsided in the area of the rear whell. The wheel is leaning (neg. camber) about 10 degrees.
What component would fail first? the arms look and I believe the curveture of the spindle failed?
Jan 20, 2008 at 11:51 AM
  • 31,937 POSTS
Hi there,
You will have to consider all the rear suspension components , and the strut top mounting in the body. The most obvious would be the stub axle assembly . lower control arm, and trailing arm. You will have to have the rear end alignment checked as a Deg or 2 will be enough to destroy a new tyre very quickly and give driving stability problems as well.
Mark (mhpautos)
Jan 20, 2008 at 8:20 PM
