2001 Hyundai Sonata Radio antennae
2001 HYUNDAI SONATA
180,000 MILES • 6 CYL • FWD • AUTOMATIC
JELLSEY
Can ayone provide instructions for changing the electric antennae? Thanks!!!
Oct 24, 2008 at 10:48 AM
ZACKMAN
  • 4,202 POSTS
Pop your trunk. Remove the carpeting on the driver side. You may have to remove some plastic retaining clips to do so. You will see the antenna attached to a bracket, held by 2 or maybe 3 10mm screws. Need to detach the electrical connector, antenna wire extension and a ground wire to the body.
From outside, remove the nut that holds the antenna. I don't remember the size, an adjustable wrench works just fine.
When installing the new one, be sure to pay attention to fuel door release cable.
Oct 31, 2008 at 7:39 PM
