oil burning
SNEETA98
4 cyl Two Wheel Drive Automatic
i just recently had a oil leak repaired and now it smells like oil is burning and there is smoke coming out the tail pipe and also the check engine light is on. Auto Zone check the light and i was told the the egr valve is blocked but i just had that repaired 2 months ago can you please tell me what is going on
Mar 24, 2009 at 9:30 AM
The code may have been for the EGR but that is most likely not going to mean it is blocked. That is one possible cause but if it was just replaced, then it is unlikely the issue and there is another issue with the EGR.
However, we need to start with finding out what code is there so that we can work through that issue.
As for the oil burning that, could be related to the EGR issue so we need to start with that.
https://www.2carpros.com/articles/blue-smoke-from-engines-exhaust
However, if you are burning a large amount of oil, then that could explain why they say the EGR is stuck so again, we need to start with what code is there and go from there.
Thanks
Nov 13, 2021 at 11:08 PM
