2001 Hyundai Sonata Obtained Error Codes:1529, 0720, &
2001 HYUNDAI SONATA
118,000 MILES • 6 CYL • FWD • AUTOMATIC
SPOON_WOODS
I'll be driving and the RPM's will briefly peak, then the car will kick down to third, and will stay there until I restart the car. Codes seem to tell me this is a Speed Sensor and O2 Sensor issue, is this correct? If so, is the only prognosis sensor replacement? Finally, are there any other issues I should be looking out for that can arise from this problem?
Apr 17, 2009 at 12:56 AM
BUDDYCRAIGG
  • 2,262 POSTS
yep, it's probably the speed sensors, I believe your car has 2 of them in the transmission.
it's a common problem with that year of Hyundais.
Apr 17, 2009 at 5:19 AM
SPOON_WOODS
Alright, well I'll see how much Ebay has on those parts. I'm assuming I should replace both sensors, right?
Thanks for the confirmation guys!
Apr 17, 2009 at 7:38 AM
BUDDYCRAIGG
  • 2,262 POSTS
actually, call your local dealer.
there was a campaign (a recall) for them on some models.
when ever a manufacturer does that, the cost of the parts go way down, to lower the price of the warranty bill.
and i dont remember which models it was, but some had both sensors built into one harness, with only one plug, so they came together.
and make sure to ask to talk to the service department to see if you car would still be covered under the campaign, have your VIN handy when you call.
good luck
Apr 17, 2009 at 8:38 AM
