I've looked in the owner's manual, but there aren't detailed enough instructions on how to change a burned-out headlamp bulb. In talking with other people, I've been told that there should be a tab behind the headlamp assembly to pull out the old bulb and replace it with the new one (I've already bought the H7 bulb). Other people tell me that I need to remove the bolts holding in the entire assembly in order to access the bulb. Before I go taking out more than I need to, can you give me step-by-step instructions on how to remove the burned-out bulb and install the new one? Thanks for clearing up this confusion. Rev. Dr. Karl R. Kraft (DMinCheez@aol.com)
Feb 7, 2008 at 7:42 AM
