code p1529?
116,000 MILES • 6 CYL • FWD • AUTOMATIC
MKKTAI1
the sonata shifts abruptly at cruising and check engine light comes on. scanner gives the code p1529 - tcm, transmission control module, and refers to dealer. what does it mean? is it transmission or speed sensor or some other part?
May 5, 2010 at 9:28 AM
  • 31,937 POSTS
Hi there,
This code will be referring to a fault with the transmission ECU which is common here is how you can replace the unit in the diagrams below.
Engine/Transmission Control Module (E/TCM) (A/T) (2.4L) Behind lower center of dash.
May 5, 2010 at 11:46 AM
