2001 Hyundai Sonata
MALCOM023
  • 2001 HYUNDAI SONATA
  • 4 CYL
  • FWD
  • 100,000 MILES
How do I take out transmission
Wednesday, November 12th, 2008 AT 7:01 PM
  • 31,937 POSTS
Hi there,
This is a bit complex to do here, you should get a manual as it will give you step by step instructions with pics to assist you, but basically, jack up and remove wheels and drive shafts, remove all electrical connections, cross member and transmission mounts, don't allow the weight of the engine & transmission hang on the remaining mounts, you will need an engine brace bar. Remove starter motor, selector linkage, speedo, trans cooler lines, lower cover plate and undo torque converter bolts, support transmission and undo bell housing bolts and with draw from engine, Go get the manual and have a read up on trans removal before attempting this job.
Mark (mhpautos)
Wednesday, November 12th, 2008 AT 7:13 PM
