2000 Hyundai Sonata transmision downshifting
ZSAY
Transmission problem
2000 Hyundai Sonata 6 cyl Automatic 120000 miles
transmission thumps when i'm slowing down or breakiing just before I stop.
Jun 23, 2008 at 5:02 PM
KHLOW2008
  • 41,812 POSTS
Hi zsay,
You need to have the trans checked. Most probably the trans valve body and solenoids are not working well. The symptoms points to line pressure instability.
Jun 25, 2008 at 3:43 AM
ZSAY
[quote:cf6b246dd3="KHLow2008"]Hi zsay,
You need to have the trans checked. Most probably the trans valve body and solenoids are not working well. The symptoms points to line pressure instability.[/quote:cf6b246dd3]
Thanks. I was wondering if the input speed sensor has anything to do with it ?
Jun 25, 2008 at 12:19 PM
KHLOW2008
  • 41,812 POSTS
Hi zsay,
If the speed sensor is faulty, the speedometer won't work and it will cause erractic gear shifting.
The TCM operates with signal from the speed sensor to provide correct time for gear changes so if it is malfunctioning, get it replaced first.
Jun 26, 2008 at 2:55 AM
ZSAY
thanks again. I'll have it checked out.
Jun 27, 2008 at 1:28 AM
