2000 Hyundai Sonata rear hub noise, sounds like dry bearing
THICK
Drive Train Axles Bearings problem
2000 Hyundai Sonata 6 cyl Two Wheel Drive Automatic 40k miles
Can the rear hubs be taken apart so I can pack the wheel bearings? The auto parts store has no kits, just the whole hub replacement
May 18, 2010 at 4:47 AM
  • 31,937 POSTS
Hi there,
If fitted with rear disc brakes this is a sealed bearing, if fitted with drum brakes these are inner and outer cup and cone bearings that can be serviced.
mark (mhpautos)
May 18, 2010 at 11:19 AM
