2000 Hyundai Sonata no start after fueling up
72,250 MILES • 6 CYL • 2WD • AUTOMATIC
SANDRAD
when i go to get gas i shut the car off, after fueling start the car and nothing. i dont even hear a crank, i always have to start the car again and it works, WHATS GOING ON??? no one can figue it out. Should i leave the car running? I use regular gas, is this the problem?? HELP PLEASE!!!
May 21, 2008 at 1:54 AM
MASTERTECHTIM
  • 4,750 POSTS
no. its got nothing to do with getting gas, most likely the cause of your problem is a faulty starter and you only notice it after getting fuel is because when the engine is hot and shut it off for gas then you try to restart it, the starter has a dead spot. i own a gas station repair shop and this happens alot with the hyundai. hope this helps
May 21, 2008 at 3:34 AM
