2000 Hyundai Sonata MPG down, rough idle
65,000 MILES • 4 CYL • 2WD • AUTOMATIC
WRIGHTGJ
I've had problems over the past several months with my Sonata. Check Engine light came on, and I pulled codes for cylinder 3 misfire and system too lean. Throughout these months, the CE light will turn off randomly (it seems) while I'm driving, and then come back on a few days later, with the same codes. My gas mileage has gone from 28 to 22-23 and it idles rough when I'm sitting at lights, etc. I had just replaced the spark plug cords a month or so before this. I took the car in to get the fuel injectors cleaned, but that didn't really help. I cleaned the MAF sensor several weeks ago, which seemed to help a little. The light went off after this, and has stayed off, but performance is still bad. I had new spark plugs put in about 20,000 miles ago, and I put a K&N air filter in a couple months before all this started happening. Any ideas? I appreciate your help.
Mar 20, 2008 at 6:06 AM
JR0D117
I have the same problem. does ne one else know the cause???
Aug 6, 2008 at 3:23 PM
IMICHAEL
[quote:b0ad25cf25="wrightgj"]Engine Performance problem
2000 Hyundai Sonata 4 cyl Two Wheel Drive Automatic 65000 miles
I've had problems over the past several months with my Sonata. Check Engine light came on, and I pulled codes for cylinder 3 misfire and system too lean. Throughout these months, the CE light will turn off randomly (it seems) while I'm driving, and then come back on a few days later, with the same codes. My gas mileage has gone from 28 to 22-23 and it idles rough when I'm sitting at lights, etc. I had just replaced the spark plug cords a month or so before this. I took the car in to get the fuel injectors cleaned, but that didn't really help. I cleaned the MAF sensor several weeks ago, which seemed to help a little. The light went off after this, and has stayed off, but performance is still bad. I had new spark plugs put in about 20,000 miles ago, and I put a K&N air filter in a couple months before all this started happening. Any ideas? I appreciate your help.[/quote:b0ad25cf25]
Oct 4, 2008 at 8:40 AM
