2000 Hyundai Sonata couple problems.
ARASH123
  • 22 POSTS
Engine Cooling problem
2000 Hyundai Sonata 6 cyl Two Wheel Drive Automatic 80k miles
my car recently has had 3 problems. 1 is idle sensor issue, oxygen sensor issue and overheats when idling.
question1: how many oxygen sensor are there on my car? and locations? can I do it myself?
questions 2. Are universal 12" fans fit my car? my fan is working finicky( turns sometimes then stops then I hit the fan physically it starts going again).
****Since I removed the idle sensor to put on cam sensor. Can it just be I placed on wrong when i screwed it back on? or the sensor is gone( computer gave error code).
Aug 28, 2010 at 7:44 AM
KHLOW2008
  • 41,812 POSTS
Hi arash123,
Thank you for the donation.
There are 4 O2 sensors in your vehicle and it can be a DIY job but access to some are not that easy.
Fans motors are not universal and there are various types. You need to get the one that fits and the fan blades can be reused.
When you need to judder the fan into motion, it indicates the carbon brushes are running out and it is a matter of time before it fails completely.
What is/are the trouble codes that you are getting?
Aug 29, 2010 at 8:43 AM
ARASH123
  • 22 POSTS
A guy did a quick scan on my car because the car was having idle trouble. The rpm on idle is way too high. ex. when the car is on uphill and on idle it drive easily with decent speed which I feel is strange.
Also, question about the two front fan. The left is radiator fan? and right is a/c fan? or vice versa? and are they same fan or different fans to be installed. furthermore,le do I need to change both fan or one should be enough for now? ( again left fan needs to be hit to rotate again right does not work at all)
HE also got oxygen sensors. Which I have to do diagnostic test again to determine which one?
Thanks.
Aug 30, 2010 at 3:51 AM
KHLOW2008
  • 41,812 POSTS
When a scan is done, trouble codes would be retrieved. I requested for the trouble codes but they were not provided.
Right side is the condenser fan while left is the radiator fan. If only one is faulty, you need not replace both.
Aug 30, 2010 at 5:29 AM
ARASH123
  • 22 POSTS
hi I changed radiator fan. The car does not heat up as much as it did before. The fan turns on nicely. But although it is very hot day today the gauge will slightly go up abit passed the center when Idle still. This is worrying me. Not as intense though.
I put it up diagnostic: and this what I got.
P1510
p1511
p0120
p0134
I wonder if the engine is over running and heating up fast?
I had never had these codes before I changed the camposition SENSOR. Wonder if the mechanics broke these trying to get to the cam sensor which was difficult to get to.
*****Which the oxygen code . P0134 I got no activity (B1/S1) which oxygen sensor is that on Hyundai sonata 2000 v-6?
Sep 1, 2010 at 8:09 AM
ARASH123
  • 22 POSTS
furthermore? I bought a idle control valve. Should I buy a throttle sensor as well ?
Sep 1, 2010 at 12:19 PM
KHLOW2008
  • 41,812 POSTS
Before proceeding further, check if the TPS and ISC connectors had been mistakenly swapped. ISC connector should have the following wire colors :
1. Orange/black
2. Blue
3. Pink.
Throttle Position Sensor has :
1. Green/White.
2. Blue
3. Black/White
P0134 = Bank 1 sensor 1 = on bottom of right exhaust manifold. Check the wiring connections first.
Sep 2, 2010 at 2:26 AM
ARASH123
  • 22 POSTS
hi thanks,
The wiring seems fine as you said. One think i am wondering is do I need to cleanse the throttle body itself too?
couple weeks ago I got this engine cleanser that you put in your gas pump. I wonder if that did something?
To check for wiring o2 sensor do I do it with ohm meter?
Thanks.
Sep 2, 2010 at 2:59 AM
KHLOW2008
  • 41,812 POSTS
Here are diagnostic procedures.
DTC P0133, P0134: FRONT HO2S CIRCUIT SLOW RESPONSE OR NO ACTIVITY DETECTED
NOTE:
There is a Heated Oxygen Sensor (HO2S) before and one after the catalytic converter. The front HO2S measures oxygen content of exhaust gases and is used to control air fuel mixture. The rear HO2S is used to determine the efficiency of the catalytic converter. ECM calculates catalytic converter efficiency by comparing front and rear HO2S signals.
Failure Conditions
1. ECM will set DTC P0133 and illuminate MIL when ECM does not sense the following condition during 2 drive cycles:
• Over a period of 2.3 seconds, ECM must detect 10 cycles from lean-to-rich or rich-to-lean when engine speed is 2000-3000 RPM, engine load range is 1.9-4.7 milliseconds, catalytic converter temperature is more than 673°F (356°C) and system is in closed loop.
• ECM must make some correction in air fuel ratio within 133 seconds when engine speed is 1600-2400 RPM, engine load range is 1.35-1.80 milliseconds, catalytic converter temperature is more than 673°F (356°C) and system is in closed loop.
• DTC P0133 indicates engine air fuel ratio is not being adjusted by front HO2S signal or ECM as expected, or as often as expected when engine is at normal operating temperature or normal use.
2. ECM will check rear HO2S operation after engine has operated for 3 minutes and 20 seconds. ECM will measure front HO2S output voltage when rear HO2S output voltage is more than 500 mV (0.5 volt). ECM will set DTC P0134 and illuminate MIL, if during 2 drive cycles the front HO2S output voltage is not 400-600 mV (0.4-0.6 volt) for 5 seconds. This DTC indicates front HO2S is not active within expected range once the engine is at normal operating temperature.
Test Procedures
1. Turn ignition on and connect scan tool to data link connector. Verify DTC P0133 or P0134 is set. If DTC P0135 is also set, repair DTC P0135 first.
2. Start engine and allow to idle at normal operating temperature. Increase engine speed to 4000 RPM. Using scan tool, monitor HO2S voltage. If voltage is zero volts, go to next step. If voltage is constant and approximately 450 mV (0.45 volt), go to step 4 . If voltage varies, but stays less than 500 mV (0.5 volt - lean), go to step 6 . If voltage varies, but stays more
than 500 mV (0.5 volt - rich), go to step 7 . If voltage varies between 100 and 900 mV (0.1-0.9 volt), go to step 8 . If voltage is constant and approximately 5.0 volts or 12.0 volts, repair short to voltage in wiring harness. When repairs are completed, clear DTCs and
verify HO2S operation.
3. Disconnect front HO2S 4-pin connector. If DTC P0133 is set, voltage displayed on scan tool should be approximately 450 mV (0.45 volt). If DTC P0134 is set, voltage displayed on scan tool should be approximately 500 mV (0.5 volt). If voltage is as specified, replace suspect HO2S. If voltage is not as specified, repair short to ground in Yellow wire between HO2S connector terminal No. 1 and ECM 88-pin connector terminal No. 12. When repairs are completed, clear DTCs and verify HO2S operation.
4. While engine is operating, backprobe between HO2S 4-pin connector terminals No. 1 and 2, and measure voltage. If voltage changes from less than 500 mV (0.5 volt) to more than 500 mV (0.5 volt), go to next step. If voltage does not change, replace HO2S. When repairs are completed, clear DTCs and verify HO2S operation.
5. Turn ignition off. Disconnect front HO2S 4-pin connector and ECM 88-pin connector. Using a jumper wire, connect HO2S connector terminal No. 1 to ground. Measure resistance between ground and ECM connector terminal No. 12. If resistance is one ohm or less, ensure ECM connector terminals are clean and tight. If PCM connector are okay, replace front HO2S. Clear DTCs and verify HO2S operation. If problem persists, replace ECM. If resistance is more than one ohm, repair open or cause of high resistance in circuit between HO2S and ECM. When repairs are completed, clear DTCs and verify HO2S operation.
6. If voltage varies and is always less than 500 mV (0.5 volt - lean), check air inlet downstream of Mass Airflow (MAF) sensor for leaks or damage. Check exhaust manifold for cracks or leaks. If any leaks or damage is found perform repairs as necessary. If no leaks or damage is found, go to next step.
7. Perform fuel pressure inspection. If fuel pressure is within specification and no pressure leak-down is detected, go to next step. If fuel pressure is not as specified, repair fuel system as necessary. When repairs are completed, clear DTCs and verify HO2S
operation.
8. Turn ignition off. Disconnect ignition coil connector. Connect voltmeter between negative battery cable and cable attachment located on engine. Measure voltage drop across negative battery cable while cranking engine. If voltage drop is less than 0.5 volt, go to next step. If voltage drop is more than 0.5 volt, replace negative battery cable. When repairs are completed, clear DTCs and verify HO2S operation.
8. Disconnect negative battery cable and measure resistance between generator housing and engine ground point. If resistance is one ohm or less, go to next step. If resistance is more than one ohm, clean mating surfaces of generator housing and engine. When repairs are completed, clear DTCs and verify HO2S operation.
10. If MIL is illuminating intermittently and DTC P0133 is set, problem is most likely a poor ground circuit. Clean negative battery terminal and engine ground. In addition, clean mating surfaces of generator housing and engine. If MIL was illuminated and DTC P0133 or P0134 is set, replace front HO2S. When repairs are completed, clear DTCs and verify HO2S operation.
© 2008 Mitchell Repair Information Co., LLC.
Sep 2, 2010 at 5:30 AM
ARASH123
  • 22 POSTS
THANK YOU . right now I am scared of engine overheating I will take care of that after.
here is what I have done.
1. I opened the cap of radiator and let the coolant pour out with guidance of mechanics. I noticed lots of bubble and rust as it was rushing out. what does that mean?
2. I noticed the radiator fan was finicky on and off when i hit it turned on. so I replaced the fan motor and now it works fine. (a/.c fan does not work still.)
3. next i checked the the water pipe out of engine and radiator system and it was hot and so was thermostat. very hot? why?
could this mean radiator problem?
I am baffled. what's wrong. I can tell the engine is hot you can barely touch it and also when driving the temperature gauge is fine but when is idle it starts to rise. Please help me, i am going insane i spend alot already and have no money to buy new car since i spend alot on this car. I thought fixing fan as mechanic said would solve the problem.
Sep 2, 2010 at 2:02 PM
KHLOW2008
  • 41,812 POSTS
You should not have attempted to open the the radiator cap when the coolant is hot. It should be done on a cold engine.
When the coolant have heated up and there are air trapped in system, the coolant would bubble out.
It could mean a bad head gasket as well.
The radiator fan working when you vibrate it is because the cabon brushes are almost worn and have intermittent vontact. It would fail completely sooner or later. As to the condenser fan, it could be faulty. One way of test it is to disconnect the connector and apply direct battery voltage to 1 terminal and grounding the other.
The upper hose would be hot when coolant is being sent to the radiator to be cooled. If the lower hose is hot, then the radiator could be partially clogged reducing its cooling efficiency. With only one fan working, the cooling efficiency would be lower and prolonged starting of the engine could cause the temperature to increase gradually.
Sep 3, 2010 at 12:09 AM
ARASH123
  • 22 POSTS
hi,
I changed my oxygen sensor,
I had the gasket, radiator, and water pump inspected and fan again and I was told they are all fine. the conclusion is my engine is overused. the errors I got throttle sensor and idle valve control problems. Since someone amateur took them off and put them back on one may have caused the errors or the throttle sensor is gone or wiring is circuit problem is happening. Is there a particular way you would put on the throttle sensor?
Sep 4, 2010 at 6:15 AM
KHLOW2008
  • 41,812 POSTS
If the TPS is removed and installed, it has to be calibrated/adjusted correctly. Sonata (2.5L) 1. Turn ignition off. Disconnect TP sensor 3-pin connector. Measure resistance between TP sensor terminals No. 2 (sensor ground) and No. 3 (sensor 5-volt supply). See Fig. 1 . Standard resistance value should be 3500-6500 ohms. If resistance is not as specified, replace TP sensor. If resistance is as specified, go to next step.
https://images.2carpros.com/forum/automotive_pictures/192750_TPS00SonataFig01_1.jpg
2. Measure resistance between TP sensor terminals No. 1 (sensor signal) and No. 2 (sensor ground). Open throttle slowly from idle position to wide-open throttle position. Resistance should change smoothly in proportion to the throttle valve opening. If resistance changes smoothly, go to next step. If resistance does not change smoothly, replace TP sensor. 3. Ensure basic idle speed is correct. Turn ignition off. Disconnect TP sensor 3-pin connector. Using jumper wires, connector an ohmmeter between TP sensor terminals No. 1 (sensor signal) and No. 2 (sensor ground). Insert a 0.0256" (0.65 mm) feeler gauge between throttle level and throttle stop. 4. Loosen TP sensor mounting screws and rotate sensor fully counterclockwise. Ensure continuity exists between sensor terminals No. 1 and 2. Slowly turn sensor clockwise until continuity does not exist between sensor terminals No. 1 and 2. Tighten sensor mounting screws. 5. Reconnect TP sensor connector. Using a voltmeter, backprobe sensor connector terminals No. 1 (sensor signal) and No. 3 (5-volt supply). Turn ignition on, and measure TP sensor voltage. Voltage should be 250-800 millivolts. If voltage is not as specified, ensure TP sensor adjustment is correct and wiring harness is okay. Remove feeler gauge, and turn ignition off. Perform additional repairs as necessary.
Sep 4, 2010 at 7:06 AM
ARASH123
  • 22 POSTS
Problem solved. The wires were crossed. I cant believe it. I went to a mechanic to save couple hundred and ended up costing me 700. I hope this can become a lesson. Engine runs beautifully now. engine light is off.
Sep 4, 2010 at 8:23 AM
KHLOW2008
  • 41,812 POSTS
Thank you for the input and glad to know you have fixed the problem.
I would never recommend replacing parts till it has been confirmed it is faulty. To use a trial and error method is costly and most of the time a waste of resources.
Thank you for using 2carpros and have a nice day.
Sep 6, 2010 at 4:29 AM
ARASH123
  • 22 POSTS
hi,
I know I should start new topic but I have spend so much money on the car I am short on cash. If you can still help me that is great.
Car engine light is off. Computer says nothing wrong with engine on several tests.
From advice from mechanic...I changed camsensor, throttle sensor, oxygen sensor and Idle control valve. The car is running fine. However, again I have noticed the car kicks when around 40kmh when I let go of accelerator and repress it.( NOT always but sometimes ther is "voushshsh" feels to me like gas is stock then it gets pushed in) Thats the only speed I have noticed I am not sure thats means something. This problem is not a big deal but I noticed when I accelerate very slowly it does not kick as much or not at all. The car is fine in higher speed without a problem, but I spend over 700 to fix this problem and its not fixed.
Some people say since it has gone 130k it might need Tune up and gas filter change? But I am not spending a penny until I am sure anymore.? or some people say your car doesn't know your driving habit.Or I am not driving it well and its the way I press the gas peddle.
Could there be other reasons for car kick on acceleration?
Sep 16, 2010 at 8:58 AM
KHLOW2008
  • 41,812 POSTS
No problem, we can continue from here anytime.
If it is a filter, it should be occurring at all speeds under accelerating condition.
Try shifting to 3 and see if the same conditions occurs. Just want to confirm it is speed and not engine rpm related.
If it is speed related, it could be the trans that is causing the jerking.
Sep 17, 2010 at 1:10 AM
ARASH123
  • 22 POSTS
Can a simple flush help the problem? What can I do do about it?
Sep 17, 2010 at 1:34 AM
KHLOW2008
  • 41,812 POSTS
We still do not know the actual problem so we need to figure it out.
Problem could also be spark related as the hesitation could be misfiring which is not registered in the PCM because it does not occur all the time. A fuel pressure loss can also cause the problem.
If it is a transmission fault, a flush might not work, unless it is due to the fluid condition.
Try to note the engine rpm and gear position when problem occurs.
Sep 17, 2010 at 1:54 AM
ARASH123
  • 22 POSTS
hello,
I did a smog test today. I got HC=0, CO2=0 great at idle levels. failed NOx. mine was 1000ppm(limit 400)
The mechanic ran test on cat (seemed fine) and oxygen sensors and he said atleast 2 front sensors are not functioning probably. He mentioned the oxygen sensors go from 5v to 1v backforth on graph. HE also will check MAF. HE says it will pass after if i change them and service MAF. Will it? don't want to waste my time and money anymore.
Again symptom of my car are that engine seems hot (my guess why such high Nox). and car hesitates when accelerating as I mentioned above.
Sep 17, 2010 at 7:36 PM
KHLOW2008
  • 41,812 POSTS
If the catalytic converter is good and the O2 sensors are out of specs, it can cause the hesitation. Since the smog test failed and the O2 sensors are deemed bad, you have no other option except to replace the O2 sensors and hope that they are the only cause of the hesitation.
They should at least get you to pass smog test.
Sep 18, 2010 at 1:58 AM
ARASH123
  • 22 POSTS
I changed my front 3 spark plugs and one broken wire now and i have very bad rough idle and i could hear clicks? whats going on? should I put the old ones back on? the new ones were bought from part-source. what are the order of the plugs just want to make sure i didn't put wrong plug in wrong socket on coil. Car is Hyundai sonata 2000 gls. now check engine light is on too. I just want to get my already bad car to were it was back atleast.
Sep 21, 2010 at 10:54 AM
ARASH123
  • 22 POSTS
Sorry to bug you guys.
but I fixed the problem I put two wires on wrong socket. I manged to change my three front spark plug myself. I decided to do that because I saw two of the wires were broken. now the engine is fine but with engine light on.
Furthermore, I just need to unhook battery to clear the code that was created by coil misfire code. I don't have the tool. What kind of alternative tool can I use to unhook battery?
I also changed my maf sensor with another cars also. for only 30 bucks. That was good news. Hoping anything would fix NOX problem. Don't know if i have the capability to change the 3 spark plugs from the back. Is it easy job as front ones?
The emission place that i did my emission place told me my oxygen sensor were bad cost me 50 bucks to diagnose it
afterward, I took the car to the mechanic who changed one pre-cat oxygen sensor and charged me 130 bucks telling me oxygen sensors are fine and nothing is wrong with the one they changed I was so pissed he even mentioned me paying him he is just checking to see what he has done why charge me?. I will never go to those money hungry crooks.
Apparently my precats are suppose to be correcting itself and my precats were jumping up and down on graph correctly ( completely opposite from the emission center told me (which was the graph of the oxygen sensor should be be flat ) I verified from three to four other mechanic places that is absolutely wrong what emission place told me (another private crook) So you can see I am not in good mood. . I am baffled and do not trust most private mechanics anymore.
Also, my oil change is overdue does that matter before i do emission test again this Saturday?
Thanks.
Sep 22, 2010 at 2:55 AM
KHLOW2008
  • 41,812 POSTS
If the CEL is indicating, it means there are still error present.
You can get a free scan done at Autozone and get the trouble codes erased as well. If the CEL is indicating, you would not pass emission.
The oil change should not be any problem.
Sep 22, 2010 at 3:52 AM
ARASH123
  • 22 POSTS
when you do v6 Hyundai sonata 2000 tune up. DO you need a new intake plenum gasket or manifold gasket or they are the same?
Oct 1, 2010 at 8:33 AM
KHLOW2008
  • 41,812 POSTS
They are different. The plenum ( upper intake manifold) gasket is what you need. For tune up you only need to remove the upper manifold.
https://images.2carpros.com/forum/automotive_pictures/192750_Manifold00Sonata_1.jpg
Oct 1, 2010 at 10:04 AM
